C language: error: cast from pointer to integer of different size
rih5342
Marine/Ocean
I'm using Windows-7 64bit, with gcc V5.2, with MinGW, and trying to compile portablexdr-4.9.1
This piece of C
static bool_t
xdrmem_setpos(xdrs, pos)
register XDR *xdrs;
u_int pos;
register caddr_t newaddr = xdrs->x_base + pos;
register caddr_t lastaddr = xdrs->x_private + xdrs->x_handy;
if ((long)newaddr > (long)lastaddr) <== error here
return (FALSE);
xdrs->x_private = newaddr;
xdrs->x_handy = lastaddr - newaddr;
return (TRUE);
produces this error
xdr_mem.c: In function 'xdrmem_setpos':
xdr_mem.c:172:6: error: cast from pointer to integer of different size [-Werror=
pointer-to-int-cast]
xdr_mem.c:172:22: error: cast from pointer to integer of different size [-Werror
=pointer-to-int-cast]
How do I fix it?
Thank you.
Do you happen know what XDR and caddr_t are? (This is why I hate excessive typedef-ing. All it does is disguise what it's base-type truly is, which is not something you want to disguise anyway!)
It also looks like very old code. It's using the old-school function prototype.
