I'm a engineer plant in a refinery.
There is a Control Valve 3" with a bypass control valve 4".
Last time the CV needed to be get out of operation to maintenance, so the bypass got in temporal control and a strong vibration started on the bypass line and valve...as a consecuence the Bypass valve lost its seal and i think another components where affected.
So, I want to studie the whole valve system, but I'm not sure about the normatives I need to be supported on in order to do that...i mean the calculation on the bypass valve in relation with the control valve...
I've red also about trims that reduces cavitation, noises, vibration in system. How can I identify, in base on my calculations, whether i need a trim whith special characteristics or not?
Thank you! Look forward for you comments
