Hi;
As I had a hot talk with my friend over the use of bypass in Cent. Pumps I want to examine whether I am right or not?
Based on my knowledge I know three cases in which we can use bypass for Cent. pumps:
1- When the minimum flow is prone to be less than the minimum flow which was determined by manufacturer.
2- When we have a large and expensive pump and we usually want to start it with bypass. (honestly I don't know why?)
3- When we want to use a Cent. pumps for flowrate less than 5 m3/h, we choose a bigger one and with bypass we can reach to the rated flow. (I know the loss of energy but in some case this solution is economical and very attractive for managers in order to get rid of an expensive PD pump)
But a friend of mine has said that when a pump operates out of the API-610 defined operating region, and is rejected because of this deviation (let 40% of BEP flowrate) we can use a technical trick and use a bypass to push the rated point to the right of curve in the case that we cannot change the pump type or size.
I disagreed with him because I have seen just three mentioned cases in which we had used bypass and not for this one, but unfortunately I couldn’t represent any technical or standard-based reasoning.
I appreciate you if make me winner!
