Bypass of Compressor
Darshit9
1
hii..
How Bypass line used for startup the multistage reciprocating Gas compressor? ,if no unloader & bypass line is provided than what will be a breakaway torque of reciprocating compressor?...
darshit9 - Please provide a sketch and some more info. "Breakaway"?? This is usually reserved for valve action.
If there is no unloader and the overall bypass line is fully open, then final discharge pressure on the compressor will be nearly the same as suction, and startup torque will be the same as if all unloaders are open ?
