jamesbanda
Chemical
I've been doing some background reading on pressure compensation for bursting discs.. and would like to poll what other do..
in can see advantages in doing it such as.
Case 1: Corrosive vessel, relief case 10 barg at 300 C,operating temp 200C. vessel design pressure 10 barg
if you dont temperature compensate the bursting disc: Cold set at 22 would be 10 barg, so at 200C, burst pressure could be say 8 barg.
..so you cold burst the disc, and not know about it in normal operational cases..and endup having an fairly big issue due to corrision of the relief valve..
Case 2.but if you do consider case1 but temperature compensate the valve.. you could have an operational case COLD(say thermal expansion.. ).. and exceed design pressure in cold case..
so..in my view you need to consider the cold set pressure against the credible relief cases and not just in isolation against one case.. so in some cases you will temperature compensate so the burst pressure cold exceed design pressure and in other cases you will not and the burst pressure hot will "go early"..
i've read the codes api etc.. and they tend to suggest to myself to use guidance..
