eqkimball
- May 9, 2007
- 12
I need to spec a coating for an 18" carbon steel pipe w/ welded joints. This will be 3' below ground in a moist environment. The pipe is to be constantly charged with 200 psi untreated water.
Do I need an inside coating if the pipe is always full?
What is a common outer coating for this environment, that can be specified for the supplier?
Thanks.
Thanks.
