The site has excess water.
After completion of construction, there will be two feet of water above the bottom elevation of the elevator pad footing.
I need to perform a bouyancy calculation to determine the required gravity dead load to resist the upward bouyancy force imposed at the bottom of the elevator pad footing.
What is(are) the calculation(s)?
Any other helpful comments or suggestions?
Thank you in advance!
