Bulk item parameter change
SrGilberto
(Pro/Wildfire)
I'm attempting to change a parameter of a bulk item but I'm not even able to select it.
Here is what I'm attempting: In assembly mode, I select "Tools", then "Parameters", then I select "Part" (from a drop-down). Then the parameter screen goes away and I'm prompted to select the part. I assume the only way to select the bulk-item is from the model tree. When I select the part from the model tree, nothing happens (I'm not able to select it). So I can't continue until I successfully select the bulk-item.
Any suggestions?
SrG.
You might try doing it in the Model Tree. Click the model tree Settings and select Tree Columns. In the Type pulldown, select Model Params. Pick the parameter you want to change and add it to the Displayed column. Then you should be able to select the Bulk Item parameter and make the change.
Good luck!
<tg>
Telecomguy!!!
You are a good carpenter (You hit the nail on the head).
That was exactly what I needed.
Thanks,
SrG.
