Our design called for a 3-ply 2 x 12 built-up beam. The builder put a joint in the
end span (see attached sketch). This is not allowed by the NBCCanada. He has suggested a 4th ply be laminated in the end span. Essentially it seems he still
has a 3-ply beam as far as bending moment is concerned and should be OK for moment resistance He can’t get any end bearing without a lot of work. Are we
entitled to assume that the beam as now constructed will resist the horizontal
shear adequately. The span is 11 ft and the loads are just typical residential loads
