built up member w/ radius
JStructsteel
Fabricator local to me cant bend a W12 beam (12x26) and want to just flame cut a web with the radius, and then roll plates to make the webs. Would you require a full pen weld, or just calc the fillet size to satisfy the shear. Based on quick calc, 3/16 fillet seems to work. Its a 22' span, Vu is 5.4K if someone can double check me.
I'd be fine with the fillet welds rather than the full pen. In some respects, the less welding heat input the better for distortion etc.
The fillets, if done well, will mimic the the fillets of a rolled section and could add to the "authenticity" of the appearance.
Strictly engineering, though, I'm with KootK. Though I might be hesitant on the flame cutting. Put together a solid specification for cut tolerance to make sure the final product will mate up with the flange for decent welds. That would go equally for fillets or CJP.
Search another fabricator.
Thanks KootK, and PhamENG. This thing is lightly loaded, so I agree I can get away with less weld. Its all going to be covered up, so appearance not a issue.
Would you divide the welds up equally both sides?
r6155. Not an option, as I am just the engineer. Thanks though.
All else being equal, I love symmetry - so yes.
Do not arruine a nice beam W12 x 26. Use plates of same thickness and weld with qualified welder.
Another vote for both sides if accessible. Smaller welds are faster, cheaper.
Unless it was truly inaccessible, I'd require at least a ("non-structural") seal weld on the far side, even if a single minimum fillet was technically sufficient. Just to mitigate the weld being loaded in twisting about its axis.
just call me Lo.
Thanks.
r6155 what do you mean by arruine?
Sorry. I say now ruin, spoil
Got it. They are not ruining the beam, they are going to make a beam out of plate steel at the required radius shape.
I like two sided welding here too. The pre-Eng folks do one sided welding on tapered columns sometimes. Some reasons that I'd avoid that here:
1) One sided welding provides less rotational restraint to the flanges.
2) For a one off thing, I'd not be interested in taking on that extra risk for very little gain.
3) Two sided welding may help even out lateral distortion.
4) As a curved beam, your flange will be either pulling away from, or pushing into the web. I love the snot out of that occurring symmetrically rather than eccentrically.
