JStructsteel
- Aug 22, 2002
- 1,448
Got a girder truss that is a 5 ply member, about 15.5K of load. Was going to use (6)-2x6 column. I will specify a nail pattern to connect them all together.
At the top/bottom, do you folks call out for the built up column to be trimmed flush once connected together?
Do you run the top plate over top, or splice top plate at the column?
