Has anyone got any decent info on thermal lag and the effects on the buildings heating/cooling system.
I am working on a job where the client wants to do some 'new' things i.e. avoid cooling or at least reduce it by using the buildings natuaral ability to absorb heat into the structure.
I understand that concrete has a 'admittance factor' which is the ability of the fabric to absorb heat (rather than let it pass through in an equilibrium sort of way)
I need to know how for instance making the floor 300mm concrete as against say 100mm concrete will affect the building and the heating/cooling systems.
I went to see a building in Germany with an 'eco' design and this had 300mm concrete on top of 100mm insulation. There was external solar shading, etc.etc and natural ventilation.
I know that building constructed in the 1800's were relativeley thermally heavyweight and subsequently much cooler than todays modern lightweight buildings.
Anyone got any experience in this department---or is there a good 'read'anywhere?
Friar Tuck of Sherwood
