quickenberger
Industrial
- Nov 22, 2013
- 2
I have recently gotten into paintball and am looking for a more permanent solution than going to the local dive shop to get my HPA bottle refilled because they are on the verge of shutting down so there will be no HPA sources for about 50 miles. I have done quite a bit with hydraulics and wondered about looking for a series of hydraulic cylinders to make my own multi-stage air compressor. Running the general F=PA calculations I can get about 3,000 PSI with 3 stages which is what I want. For cooling I would use oil on the rod side of the cylinders where check valves force flow back to the reservoir. Air compression would be done through check valves with intercoolers between each stage and the extension, retraction of the cylinders would be done with a continuous cycle reciprocation circuit. All cylinders, hoses, fittings...etc would be rated for over 3000 PSI so that shouldn't be a concern. Basically three smaller cylinders would be forced to extend/retract by one larger cylinder and limit switches would cause a solenoid operated flow control valve to shift from retract to extend. I have most of the stuff (pump, drive engine, working rated cylinders, some hoses and lots of AN fittings) so it wouldn't be a huge financial investment. It does not have to operate quickly either. Flow control valves could time things so heat buildup is not as much as well.
My question is if this is something that someone would recommend not doing for some unforeseen reason?
Here is a site that is doing something like this for methane compression. They don't have a working prototype that I can find. Most high pressure air compressors are three of four stage reciprocating piston type with forced air cooling and large heat syncs. They are quite expensive even used, around $2500 to $4000. I am assuming that I can accomplish HPA for less than $1000 if you include the stuff I already have.
I'd love to hear your thoughts
