slickdeals
The Indian concrete code does not have any information pertaining to the design of stud rails. As a result, we are looking at other building codes which address it such as ACI.
One of the concerns I have is regarding the different load and resistance factors on which the codes are based.
For example, the Indian code ultimate design is based on 1.5 DL + 1.5 LL with material safety factors of 1.15 (steel) and 1.5 (concrete) already incorporated in codal equations.
ACI uses different load factors (1.2 DL + 1.6 LL) and resistance factors (0.75 for shear).
If I were to use the ultimate loads per Indian codes, can I design for stud rails using the ACI code? I am wondering if the phi factor of 0.75 can be equated to a material safety factor of 1/0.75 = 1.33? Will it be an apples to oranges design?
I would appreciate some discussion on this and if any of you have had to do something similar in design?
