MiniMe4Eng
Hi guys
I am trying to understand if this solution is acceptable
Here is the story: I was trying to help a friend to rebuild a deck and he wanted to reuse the existing piers (concrete footings). Another fried who is an architect came up with a new design but that requires us to shift the points where the load is transferred from the joists to the beams posts and deck supports
Below you have the proposed design that I am trying to validate with your help
The reasons for the below design are:
-he wants to place the stairs adjacent to the wall
-he wants to use the deck posts as rail posts as well
-this is replacing an old deck and I do not want to dig new holes
At the bottom I have 4 beams 2x8 (a pair on each side sitting on the deck supports)
Just below the deck I have two 2x8 beams parallel to the house, one of them sitting under the joists, the other sitting at the same level with the joists
Some measurements: the left side left post distance to the deck support is 13", the right side post (closer to the house) distance to the deck support that is next to the house is 21"
The deck is 44" high, 10' wide along the house, 8' deep (perpendicular to the house). The piers are dug down to below the frost line (48") and they are 10" in diameter.
I need to understand if this is an acceptable design I just need to know if there could be other potential issues
