This may be a stupid question, but I'm new to solid works, but definitely not new to CAD. I have two "cut-extrude" sections with the same error: "Warning, could not find face or plane" How do I fix that?
Another unrelated question. How do you make a dimple in sheet metal. I assumed it would be using draft and linking the thickness to it but either I'm doing it wrong or I'm on the wrong track?
"Dimples" would be a good way to introduce yourself to sheet metal palette features. Look in the help unde "Palette Features".
In the default sheet metal palette, you'll find all kinds of embosses, lances, and extrusions to play with. Chances are you can get what you want by modifying one of them.
There's no double-lock defense; there's no chain on my door.
And I'm available for consultation,
but remember your way in is also my way out
