I have a horizontal pressure vessel designed to ASME Sec VIII, Div 1. If I add longitudinal stiffeners at the point of maximum compressive load, am I still limited by the allowable compressive stress as determined for B in UG-23(b)(2) or may I use the higher limit of the tensile as in UG-23(b)(1).
I was once told that the factor B calculation was only for unstiffened cylinders, I cannot verify that statement.
