i am designing a drill casing pulling lug. the lug will never see the loads it is designed for but i want to have a complete design i can stamp and file away.
Question: how do you determine the shear stress that is used in the formula (3-37) that determines fcr? the most conservative way is to use a single plane thru the lug, not sure if that is right.
any thoughts are appreciated,
i have attached a sketch and some calcs so you can follow along my train of thought.
thanks in advance
thanks in advance
