BS EN 1991-1-4 Wind Actions
rho in kg/m3
vb in m/s
qb in Pa
That leads to:
- force [kg.m.s-2] = [N]
- pressure [kg.m.s-2.m-2] = [kg.m-1.s-2] = [Pa]
- qb [kg.m-3.m2.s-2] = [kg.m-1.s-2] = [Pa]
Is there a project or an example where the Wind Actions is applied?
For your most recent question:
It somewhat depends what you're trying to apply it for.
If its a building, you might want to generate floor-by-floor diaphragm loads.
If it's a roof/canopy, then you might want to consider area pressures.
The usefulness of any example then depends on what type of structure you're analysing.
Ilyas
There's a lot of publications in the European Commission JRC's website:
Link
Thanks for the help. What is the difference between wind pressure (5.2) and wind forces (5.3), and what kind of load should be applied to the building facade?
well.... pressure is force divides by area ....
Wind force is given in [KN]
Wind pressure is given in [KN/m^2]
Are you student ???
