Broken view in revolved section
deepdasr
Automotive
Hello
Can we give view break in revolved section.
Because i am unable to give view break in revolved section
Please help me out from this.
Can you give some more detail please? and Which version of NX are you using?
Do you get an error message of some kind?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Yes Nx 9
Actually after taking view break command unable to select the viEW which we want to brak
Can you share the model and Drawing?
NX9 / TC10.1.2
Sorry but actually we are in restriction to share anything outside..
Can you create something similar which you are allowed to share? (as an example)
It would be very difficult to determine what the cause is without an example
NX9 / TC10.1.2
Actually you can try at your Nx also
Give one view in drafting environment and create a revolved section and try to view break the section view.
I am unable to do that try at your end if possible
Deepdasr, we do not understand what your problem is, you need to clarify the question.
You can do that with an illustration such as an image, or a NX demonstration example if you have restrictions on your production drawings.
Because we do not understand what the problem is, it does not help that "you can try that at your nx also".
Tomas
Quickly tested it and it seems to be as designed that you cannot create a broken view from a revolved section view.
Only quick and dirty solution would be is to create the revolved section view twice (hide the second section line) and as such create the broken view yourself.
NX9 / TC10.1.2
