The seat of the taper lock at the hub / shaft connection is a known area of concern for crack development / failure with belt conv. pulley shafts.
As for fatigue, assuming just 10/24 and 6/7, we look at +2,5*106 cycles and are well placed for relevant failure. Pls. see attached.
As for overtightening, I would not think that anyone should have been retightening the taper lock device, pulleys being normally delivered as an ready-to-use integral unit of pulley shell + shaft + locking devices. This is, at 1,5 month from delivery, entirely within the scope of mfgrs warranty.
As for checking, this calls for a full blown investigation into
- loadbearing capacity of the shaft zone affected, considering all stress raisers
- metallurgical exam & crack analysis
- load amplitudes and cycling characteristics
- operations (extraordinary events, op. history until failure)
- design environment and influences from pulley bearing & support design
and check this back against the design calculations.
No one should accept to work with a system where such failure might occur again & at random. And from a legal p.o.v. you are now "in" to know there's a weakness which may have severe effect at least for operations material , if not for the operators. What if the belt does really start to burn & starts a fire, which is a real (in my prof. experience) risk with such failure mode?
In belt conveyors, the rule is: "Protect the belt", it's the major item in capex.
R.
RSVP
