I've got a situation where an F1554 gr55 anchor rod is sheared off at the bottom of base plate elevation. Contractor wants to weld fill the hole in the base plate to weld the top of the sheared anchor rod to the base plate.
I thought welding anchor rods to base plates was a bad idea, but I cant remember why. Any thoughts on if this is an OK procedure, or recommendations for another option? There is no uplift on this column.
