BNicolas
Materials
- Jun 11, 2012
- 6
I hope i'll be understood though my english has to be worked.
The problem concerns injected electrical connectors made of PBT Duranex(c). There are little elastic "clips" which let the conector pass at first and block it (hoping i'm clear). And so, the problem is that about 5% of the parts have the clips brittle and then break during the resistance test (A needle enter the hole, push the clip to simulate the connector before a camera checks that all clips are here).
I'm about to do some tests on parameters and i'd like to have you're thinks.
An observation was that clips whick break are mainly at a position which partially filled in first time and fully at last (know through tests whith not enough material)
I have 2 ideas for solution:
-Not hot enough at nozzle so that the fluidity is not good enough (at the moment about 250°C)
Mold is to cold so that there is a too fast cooling of the material inside which causes layers apparition and decreased pass size to fill the clips. (clips enter is not more than 1mm)
Both are linked
-A study carried out by the european plasturgy center (PEP) showed that ther eis an amorphous area at the base of some clips, could it be more brittle than the crystalline one? And so the material should be kept cooling longer. (we saw that a longer time for cooling without any pressure remaining decreased broken parts to 0.2%, but after some time it goes up again)
Thank you for reading and for the help you may bring.
Nicolas
Both are linked
Nicolas
