In order to correctly model or calculate bridge scour, do I need to consider the effect of underground (under riverbed) footing and piles?
I am using HEC-RAS to do my work, but it can only model the above ground part of the piers. Underground footing and piles are not even recorded in HEC-RAS.
So my questions are:
1. Under what scenarios do I need to consider the effects from underground footings and piles for scour analysis?
2. Apparently HEC-RAS is not suitable to model underground footings and piles, so what's the best alternative?
Thanks.
Thanks.
