pudmud
- Feb 16, 2007
- 1
I am new to bridge design and am designing a cantilevered retaining wall abutment (with a single row of piles under toe directly below bearing centreline)and have two queries:
1) I am used to working stress design for footings and foundations and am confused with the limit state check for sliding overturning and bearing. The relevant codes AS5100, AS4678 and AS1170.1 all seem to contradict each other. Is the criteria simply Ult. Overturning Moment < Ult. Restoring Moment and when are the uncertainty factors applied?
2) In relation to designing reinforcement for the RC abutment wall, is it a correct assumption to treat the wall as a two way slab for bending and as a column for axial loading?
Any help would be greatly appriciated.
