For anybody that doesn't know for twenty or more years in Canada we haven't mixed our salt with anything, it's applied straight up in granular form directly as a road de-icer, and the bridges are deiced more often than the roads. We've been through about a decade of climatic changes here, hovering often just below the freezing temperature.
It would be my opinion (at this tme) that the failure is cracking deterioration due to corrosion, time dependant cracking of concrete and at the end of the day poor inspection and maintenance. Chunks of concrete falling of Montreal bridges is a fairly common occurance. We will see that a number of bridges in Montreal will be closed, already I know of three since the collapse. If you've driven in Montreal this is a problem for the 'public'.
The bridge remained safe and serviceable for 36 years. We now know alot more about time dependant effects on concrete, corrossion, we certainly have the technology to inspect, and we know the construction sector in Montreal at the time was circumspect. The government needs to put this on the front burner.
