HouseBoy
- Nov 21, 2005
- 464
All,
I am looking for some specific recommendations for the anchorage of a normal brick veneer wall tie to a SIP.
The gravity load is supported on a concrete foundation.
I am wondering about the following things (for example):
Is it adequate to use the common 22 gage corrugated wall ties or must something more substantial (like pintel style or pre-bent wall ties) be used?
Is it adequate to use only one fastener or are two fasteners per wall tie required?
Is it adequate to use nails or must screws be used?
I understand that 2 fasteners are better than 1 and that screws are better then nails but I am looking for specific data and/or standard recommendations from SIPS makers for their products.
Maybe the right question is : "What are the pullout load capacities of various fasteners (nails, screws etc. ) for a give SIP facing material?" and with that information, one can determine what fastening requirements are appropriate based on some "suction loading" of the building cladding.
I am in a relatively low seismic hazard area (Ohio) but I would think this is especially important in higher seismic areas.
I find no SIPS makers addressing these questions directly.
Does anyone know of any SIPS makers that address this topic directly?
It seems to me that there ought to be some standard but I can't find any specific info.
Steve
Steve
