ArneG
- Sep 8, 2004
- 38
I have a building with clay bricks from the 1940’s. The brick has exhibited full faceshell spalling (entire face approximately 1/16” to 3/16” thick peeling off). This spalling randomly affects 3 or 4 areas of approximately 50 square feet. This spalling is probably due to the brick being sealed with a non penetrating sealer in the past. The wall parapet flashing has been replaced to reduce moisture behind the brick, and wicks will be installed in this phase of construction. There is limited area of efflorescence, no efflorescence is visible at the spalled bricks. We are in a freezing climate.
This leads to my conclusion that moisture is being trapped behind the sealant, freezing and popping the faceshells off the bricks. If the wall is tuckpointed it will allow the wall to “breathe more” reducing the moisture behind the sealant and reducing the chance that additional faceshell spalling will occur.
My questions are:
1) Is there another viable option other than stripping the sealant that will reduce the chance of faceshell spalling?
2) Is there a standard way to seal the new bricks to match the existing without sealing the mortar joints and locking in the moisture?
Thanks for your help,
Arne
My questions are:
Arne
