breaking pos or neg for 12vdc coil 1
jrick
Industrial
diagram for my time clock shows conecting the neg pole from 12 vdc supply to terminal20 and the coil to terminal21.
the other side of coil is connected to the positive side of supply.
at the time I "program" a relay in clock will connect terminal20 and 21 and activate coil which closes contacts on a 110 vac circuit to ring bell.
Problem. The only thing I have access to is two wires coming from the bell that were connected to a switch and the 110 power plug. everything else is sealed. I can not determin if the switch was breaking the pos or neg.
Will this matter if it is the positive or negative running through the relay in my clock.
AC has no positive or negative, it's AC. BUT, you must find and open/close the hot side vs. the neutral. This is something that can checked with a DVM.
TTFN
faq731-376
7ofakss
it is a 12 volt DC coil, closing contacts on 110 ac circuit.
Why do you care whether it's pos or neg?
TTFN
faq731-376
7ofakss
So sorry for confusion. The question is does anyone know whether or not it could matter if I run the positive through the relay on my time clock, when the drawing shows runing the negative. Again this is because I do not know which I have connected to the switch currently.
It shouldn't matter; the actuator ought not be magnetically poled.
TTFN
faq731-376
7ofakss
