I bought a brand-new Zipper ZI-STE1200IV on eBay (from Germany, no idea who the OEM of the unit is, but it's identical to the Parkside PGI-1200A1 generator sold in the UK).
The specs claim 1200W for 5 seconds and 1000W continuous output. I've been testing it with one of those halogen heaters that have 3x 400W heating elements. The brightness of the heating elements gives a good indication of the output voltage (faster than any digital meter can measure). I also have an inline power meter attached and a tachometer that takes its signal from a sense wire wound around the spark plug cable.
Here's the story:
1. If I turn on a 400W heating element, the revs fall, the voltage droops, then it picks up and delivers full voltage no problem
2. If I turn on the second 400W heating element, the revs fall slightly voltage drops slightly, then it picks up and delivers 800W. I even turned on the third 400W element and it managed to supply all 1200W.
3. If it's idling and I turn on both 400W elements at once (800W sudden load), most of the time the generator struggles, the revs drop, and the engine dies of low revs. Looking at what the throttle servo is doing during this time, it doesn't move when the load is first switched on (throttle remains in "idling" position, around half-open). As the engine starts bogging down over the next 2 seconds, the throttle barely opens. When the engine is really struggling it opens the throttle fully, at which point it finally dies. The engine is impossible to hand-start at this point (throttle full open) without full choke.
In addition to the above, it hunts a little (revving up and down) when cold at no load, and it over-revs for a few seconds every time a load is removed.
Any ideas what the problem could be?
Here's the story:
