CuriouslyGeorge
I forget...what is the rec'd minimum tolerance to leave when cutting a branch duct into a main? Assume cutting a rectangular duct into a rectangular duct. Hmm, what about a small circular duct cut into a duct of larger diameter?
I believe you must maintain a 2" minimum tolerance correct? If a 4x6 branch is being cut into the side of a main, the main must be at least 10 inches deep, correct? This accounts for 2" above and below the branch, right?
C.George
C.George
