May 30, 2021 #1 J Jiwan Guest How to create Brach Reinforcing Pad as per picture below in Solidworks in sheet metal. Larger ID = 50 mm, Thickness is 2 mm, and Small ID 20 mm, Thickness is 2 mm Attachments Part1.zip Part1.zip 92.6 KB · Views: 1
Jun 8, 2021 Thread starter #2 C Cadasio Guest I can't open your file at the moment but have mocked one approach, I'm sure there's a better/quicker approach but it may give you an idea Attachments test123.zip test123.zip 156.7 KB · Views: 2
Jun 8, 2021 Thread starter #3 J Jiwan Guest Many thanks, I want in sheet metal so that it be made flat. Rest is excellent and kind thanks the it. Jiwan
