The article on cryogenic processing in Heat Treating Progress is the publication of a paper given at the ASM conference last fall. It is not an advertising blurb. Yes, the author is affiliated with a cryogenic processing company, but so are a lot of other people who know something about cryogenic processing. I find, however, that not many of its detractors know much about it.
I do not believe that the relief of residual stress has a whole lot to do with the increase in wear resistance in cast iron. And, as the microstructure is pearlitic cast iron, and there is very little or no retained austenite, it cannot be the austenite to martensite transformation either. So you have to look deeper.
We believe that the benefits of cryogenic processing are from subtle changes in the crystal structure. As the temperature drops, solubility of elements in the matrix changes, vacancies move or are eliminated. We have seen some indication of this in the electronics industry. In a project done for Honeywell on thin film magnetic memory chips, Honeywell thought that they detected the movement of atoms in the structure that healed vacancies in the chip layers. The program ran out of time and money before this could be confirmed. But the removal or moving of vacancies could explain the increase in sound acuity in stereo systems after cryogenic treatment.
We know for a fact that these effects are responsible for the formation of carbides in hardened steels. (See the work by Dr. David Collins.) Nobody that I know of has proven this in cast irons, but it is plausible that carbides are formed. There is also a theory that the atom to atom spacing in a crystal structure has an ideal distance where the bond energy is at a minimum. Reducing the temperature allow this spacing to become more even and closer to ideal, creating a better crystal structure. These are unproven theories, but the do give an explanation as to why pearlitic cast iron responds to cryogenic processing when there is little or no austenite to transform. It would also explain why cryogenic processing works on brass, aluminum, silver, titanium, etc.
Cryogenic processing consistently increases the life of brake rotors two to three times. There is no doubt to that. Why? Some day we will find out. Until then there is no reason not to use this amazing process to reduce costs and increase efficiency.
Regards to all,
F. J. (Rick) Diekman
