Mr. Gudz (Marine/Ocean)(OP)25 Jun 23 11:46
"....If i measure the voltage accross the magnetic break coil it is 95volts dc, but if i disconnect the magnetic brake coil, it gives 270v dc. If i remove the wire connection and measure directlt from the rectifier, i measure only 140vdc...why it happens like this".
1. We may be able to answer better if you can furnish the brake nameplate and the control circuitry, if available.
2. It would be helpful if you can furnish the following:
2.1 With the brake in off state,
a) remove both coil leads from the terminals and measure the coil only (dc) resistance...(R) in ohm.
2.2 With both coil leads removed from the terminals; switch on the brake.
a) measure the AC power source ac voltage .....(Vac) in Vac.
b) measure the Open-circuit [= without load] DC voltage at the coil terminals...(Vdco) in Vdc.
2.3 With the coil leads connected on the terminals; switch on the brake.
a) measure the DC voltage across the [energized] coil....(Vdc) in Vdc.
b) measure the DC current flowing through the [energized] coil....(Idc) in Idc.
3. Visually check whether is there any " large" capacitor in the circuit.
Che Kuan Yau (Singapore)
