stuartfd54
Hi
Over the last 2 weeks we have had to replace the brake rectifier 3 times on a 415v 3 phase motor with 415vac/205vdc rectifier. The complete motor and brake have also been changed along with contactor.
The rectifier is fed directly from the 415v from the motor so as the motor starts the brake releases. The operation that the motor drives requires start/stop 36 times/minute.
1st question - I presume there could be a slight delay in the motor start/ brake release but could this be causing the issue of destroying the rectifier?
2nd question - Should the rectifier be connected across U1/V1 or W1 incoming to the motor or U1 and copper bar for star connection?
Any other advise would be gratefully received.
Thank you
Stuart
Thank you
Stuart
