Brackets around a dimension
silverunner
Aerospace
CA
Hello all,
I have a set of brackets around a dimension. Is there a way to control the spacing between the brackets and the dimension value?
Thank you!
dear silverunner,
You can use the offset constraint. Modifyng the offset value directly from its dimension will change the distance.
Farzad
