Hello everyone!
I'm an entry level structural engineer, working on my first few tasks. Everything has been going great and I'm learning alot. Here is a lingering question that I feel was never really explained to me in school, and I can't seem to find an answer, or maybe I'm just not understanding the answers given to me. But here goes...
If you took a simple two dimensional bay, and loaded it laterally at the top with a point load, it seems to me (assuming braced frame design), that bracing would be needed. Now in this discrete case we would only need one diagonal member to act in tension as our brace. But when we flip the direction of the lateral load, we find ourselves having to put a diagonal in the other direction, that will act in tension. My question is under this circumstance, when you either have X bracing or alternating diagonal bracings along a stretch of bays, do you need to make sure the diagonals that are in compression, satisfy the same criteria as any other memeber that would be designed for compression, say like a column?? I've read several posts here trying to find a real simple explanation and all I find are people saying things like, "tension only member this" and "ignore compression that"...but how can we design a member to act exclusively in would type of loading? And ignore another (which in most cases its the compression loading that is controling the member size)? Along the same line (but perhaps not relevant), when does a knee brace become and better option then a diagonal (excluding the added space / wide openness point), are knee braces functionally the same as diagonals and x-braces?? Some of the other posts I've read skip ahead to address the unbraced length question, which is a very intriguing and interesting disscussion by the way.
To me it seems like a no brainer, compression is compression and euler doesn't discriminate which members he decides to buckle. LTB is another failure mode (mentioned above), I understand this concept is more nebulous and even my co-workers have differing opinions on what is considered 'stiff enough' (regarding the intersection at a x-brace, and does that provide in and out of plane bracing)....but thats another post for another day...
I'm sorry if all these seem basic, but I would love to hear thoughts and explanations. I really love reading the posts here, structural engineering is such a great field and just by being a 'passive' member to this site I've learned alot...I know this is alot of stuff, and I'm grateful for any explanations on any topic I may recive. Thanks in advance!
Sincerely,
Scott
Sincerely,
Scott
