I am reviewing some braced excavation pit calcs (piles, horiz beams, and wood lagging) where in one case, there is a single brace support (the horizontal beam ). In this case the regular triangular backfill load is used to determine the brace force. The other case is where there are two brace levels and a full height UNIFORM load is used for the backfill which is=25xheight of the wall.
My question is should the first case with only one brace be checked for a full uniform load as well and should the
second case (2braces and full uniform load) the only way the braces can be loaded due to a different kind of failure wedge or should the normal triangular load be checked for this case also.
