MrEngineerUS
- Apr 9, 2013
- 46
Hi all,
I designed a braced excavation (sheet piles with walers and interior struts) and I've just been notified that the utilities that weren't supposed to interfere are now an issue. Basically, they may need to connect the new 4" utility pipe and have it run through the braced excavation.
So, my question, does anyone have experience with staging such an operation and, more importantly, do they need any special details for cutting a 4-6" hole in a sheet where the new pipe will be run?
I figured they could drive the piles to a little above the pipe depth, locally. Excavate to the pipe depth, cut the existing line and mark the pipe elevation, drive the remaining length of the sheet pile, cut the hole in the pile and reconnect the pipe. Is it possible to cut a local hole like this or would any special support be required locally?
Thanks for any suggestions!
