Box selecting multiple faces
KevinDeSmet
Computer
Apr 29, 2008
302
I'm trying to quickly select a bunch of faces, it concerns a standard part downloaded from the net that has too many little notches and details and I want to use remove face to get rid of them.
Problem is, selecting faces one by one is tedious. I can find no way to box select a whole bunch of faces. Not with the selection traps, nor with the selection filters.
There must be a way!
Certified SolidWorks Professional
Could you upload a sample file ?
Fernando
I don't know, just create a simple model and try to box select multiple faces at once. It doesn't do it. Is there any way?
You can box select multiple surfaces not multiple faces of a solid. The selection toolbar and it's options are applied to elements and not the topology of the elements.
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Derek is right, I thought you have a model done from surfaces.
But you can try to use different ways to select topology of the elements (in other words, use Look: Visible on screen (is just an example) or some other criteria.
See picture attached.
Fernando
 http://files.engineering.com/getfile.aspx?folder=c805b728-6158-4981-b8d7-479bea7ae6e2&file=Clipboard01.jpg
