wale01
- Feb 2, 2006
- 21
I have a small problem. I've been involved with a project that has a small vibration problem with floor. The floor consists of a 3" normal weight concrete (total deck thickness) w/1.0c 26 Ga. deck over 28k7 joists spaced 2'-0" o.c. spanning 38'-0". Half of the building has been built and in some areas the floor is bouncier than others (obviously to do with product location, interior partitions and so forth). We are in construction of the second phase that this point. Is there anything at this point in time that can be done to reduce the vibration? If something is done is it going to be worth it for what money will be stuck into it? I personally don't think the floors are bad at all but I can't convince the owner of this.
P.S. The floors were checked for vibrations using the AISC design guide 11 and found to be satisfactory.
Thanks for your help
