J
Jeff3fg
Guest
I'm pretty new to Solidworks, I just need help with how to extrude boss on a cut surface. I started by creating a rectangle box, then I cut a wedge out from the top, then I extruded boss a wedge on the side. The problem is the extruded boss leaves a gap at the thick end of the cut wedge. How do you make the extruded boss follow a non perpendicular surface? I added pictures to help explain my predicament.
