Borehole submersible pump repair
SA07
MU
Is it possible/recommended to repair a borehole submersible pump e.g rewind the motor locally? Will it be hermetically seal? If yes can you plz give me some make of good quality?
We are looking for an equivalent to the following nameplate. Thks
Make: Calpeda
Type: 6CS-R45
Power: 45 kW
Voltage: 400Vac
Current: 98.9A
Power factor: 0.98
Frequency: 50 Hz
Speed: 2860 rpm
Protection Index: IP68
Duty: S1
Standard: IEC 60034-1
Max Amb. Temp: 45 deg C
They say that these are rewindable.
Finding someone that wants to do it, and getting the correct wire, motor fill fluid, and seals is another issue.
