I am designing my first Booster Pump Station. The pump station will be pumping from a storage tank to a higher pressure zone system. There will be three pumps, (1) 1900 gpm (150 hp) pump and (2) Duty pumps 45 gpm (2hp). They will be connected by a manifold on the suction and discharge side. The 1900 gpm pump will be used for fire hydrant supply only (1500 gpm fire flow demand) and the smaller pumps will be used for the daily demands.
I am trying to learn about the "desirable" piping, valve, and tank configurations to minimize the effects of transient "surge" pressures. All of the pumps are on Variable Frequency Drive units. At first I was just going to use these and swing check valves to ease in and out of pump cycles. However, there isn't a lot of information about the "tried and true" configurations used for booster pump stations.
My question is: does anyone have any in-service stations that work well, and what are those configurations? Also, will I get myself into trouble by relying solely on the VFD's and swing check valves to minimize surge effects and do I need to seriously consider a surge tank? Does anyone have any design tips for sizing a surge tank?
