I am currently designing a dry pipe system for a facility (OH Group 2 occupancy) located in NYC.
I am attempting the design this system to the 750 gallon limit (with a QOD) but am finding through hydraulic calculations that there is sufficient available flow (after including the inside and outside hosestream allowance) but not enough pressure. Conversely, if I increase the main / cross main / branch diameter sizes, I get sufficient pressure, as well as flow, but surpass the 750 gallon limit. I have spent the best part of the day trying to find a system 'sweet spot' where I can satisfy both volume and pressure/flow constraints to no avail.
I am now thinking of sticking to smaller pipe sizes to keep within the 750 gallon limit, and adding a booster pump connected downstream from the city main. This booster pump would supply 30-40 psi more only.
Any thoughts and considerations on this approach? Thanks in advance.
