Boolean opperations on surfaces
MichaelkSA
ZA
Attached is a simple model of two intersecting sheet bodies.
I want to know whether it is possible to eliminate all surfaces located in the intersecting volumes between the two sheet bodies and basically be left with only that which you can see from the outside of the surfaces?
I have tried a few things with the standard 'Subtract' and 'Intersect' functions but to no avail.
Thanks in advance for any assistance.
Here's looking at you, looking at me, looking at you
 http://files.engineering.com/getfile.aspx?folder=50f9735d-590c-45c3-97d5-ae72aa4b05a5&file=part.prt
Is that attached what you're after? Why not create the revolved feature as a solid instead of sheet body and then you could use unite/subtract/intersect?
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Hi Anthony,
Yes, thank you, I see it is quite simple.
I need the bodies to be surfaces. Is it possible to extract the surfaces of the bodies after the boolean operations? I'm sure it is, I will give it a go.
Michael
Hey,
For first question: You can use Trim body twice.
For second: For exstract sheet body from solidbody You can use Extract Geometry with Type:Face; Face Option:Face Chain.
Best regards
Michał Nowak
NX9 & Tc10
Thank you Michał!
"Trim and Extend" with type set to "Make Corner". Not sure if this is a good practice but it works.
Kevin
