Kiribanda
- May 6, 2003
- 703
Gentlemen,
I have a question on bonding copper to galvanized steel.
In all electrical outdoor substations, usually the ground grid buried is COPPER. The substation fence is usually HOT DIP GALVANIZED STEEL. Normally this fence is bonded to the grid using thick COPPER wire to avoid any shock hazards on the fence. In addition to above, the same fence is also in contact with the grid through the SOIL (electrolyte).
1) Does the above setup make a corrosion cell?
2) Is there a possiblity for the fence (nobel material) get corroded and destroy after sometime?
3) How to avoid this?
Your input is appreciated.
