wagner89
- May 12, 2011
- 5
Hello adhesive experts,
I am currently working on the next generation of a solar panel microinverter and am tasked with finding an adhesive that will act as both a sealant and a permanent bond. We require the sealant aspect in order to keep out moisture and the permanent bond feature with the aim of reducing or eliminating the number of mechanical fasteners used. The adhesive needs to bond two aluminum surfaces (A380 Die-Cast and 6061) and be able to withstand a temperature range of -40 to 90 degrees Celsius, an outdoor environment, potential exposure to UV light, and have a life of 25 years. The adhesive will need to be applied in a "channel" that runs the perimeter of the product. The total volume of the “channel” is approximately 0.08 cubic inches. What would be the optimal adhesive for these requirements?
I would appreciate any information/advice/insight into the proper adhesive for this application.
Thanks in advance!
Thanks in advance!
