jjellin
- Jun 4, 2001
- 35
I need to find a "cleanroom safe" epoxy or other adhesive to bond a cylindrical spacer (of a material that is yet to be determined)inside a stainless steel tube (.125" ID, .150" OD). I was planning on the undetermined material to be a plastic, such as PPS, Peek, acrylic, pvc or other. The main concern is that the bond is "cleanroom safe", as the stainless steel tubing will come close to wafers. The bond can't be something that will crack and flake causing lots of particles. There will be minimal forces involved on the bond, strictly holding the spacer inside the tube, and preventing it from rotating or slipping out. Press fit is not an option at this point. Any thoughts would be greatly appreciated
