BOM Size and Color 1
Drhinehart
64
I have two questions about SWBOM's
1. How do you control the size of the BOM? I have been able to change the text size and save that to a template. But when I change column or row width/height they do not get saved with the template. How do I accomplish this?
2. How do I change the color of the BOM on my drawing? I have a hard time seeing the default light green table.
Thanks in advance for your help.
DRHINE
DRHINE,
2.
Look at your bom properties and see if you don't have a layer that is light green in color tied to you r bom.
If this is the case, change the layer or pick none.
The text should revert to black, as in the Solidworks text color.
dsgnr1
At some point you just have to shoot the engineer and build the dang thing.
No such layers associated with the BOM... The properties for the BOM doesn't give an option for Layers.
What version are you using? I have never seen anything but a black BOM.
[cheers]
Helpful SW websites every user should be aware of faq559-520
How to get answers to your SW questions faq559-1091
SW2005 SP4.0 SolidWorks based BOM... I thought it was supposed to be black also, but on the drawing it is light green. Driving me insane, can't see on the drawing very well and all but disappears when I move it off the sheet.
note: when I use the excel based BOM it is black.
Have a look through Tools > Options > System Options > Colors.
Try going through each item in the System Colors list to see if the light green color shows up anywhere.
Also experiment with the "skins" & Color Schemes to see if they have an effect.
Do you have a SW approved video card & driver?
[cheers]
Tools/Options/System/Options/Colors/Annotations, Non Imported
my bad (bom properties)
I meant table format.
Set table format layer to none.
Thanks, the tools/options/system options/color/annotations-nonimported was correct. For some reason my system doesn't like black at all. But I did get an acceptable color.
